My Magnum SRT8 was built Aug 22/05 and delivered August 31/05. It came with the 3 season Goodyear F-1 245/45/20’s front and 255/55/20’s rear. I intend to put aftermarket wheels on the car for the summer, using the Goodyear F-1s for now. When the F-1s wear out, I would like to go to a slightly wider rear tire probably on a 10” wide rim. The stock rims, nice as they are, will be used in the winter with winter only tires. The winter tires will likely be 255/55/20’s on all 4 corners.
I undertook to get as much dimensional and other info about the stock SRT wheels as possible so I can be sure that the aftermarket ones will clear the big brakes our cars have.
DISCLAIMERS:
1/ I have a Mag SRT8, but much of what is covered here should also apply to the 300C SRT8 too.
2/ Yes this thread might be better in the wheels and tires section, but since it is applicable to only the SRT8 I posted it here.
I had a number of questions that hopefully my 5+ hrs in the garage will help answer.
Question 1: What is the offset of the SRT8 wheel?
I had no accurate way to measure this since I could not precisely determine the centerline of the wheel with the tire mounted. But lucky for us, Chrysler may have actually stamped it on the inside of the rim: See pic of inside of rim. Can we infer from this that the offset is -25.5 millimeters?
Question 2: What do the factory rim/tire combinations weigh?
-- See pics of tire/wheel on scale—this is the 255/45 tire and it looks like it weighs about 61 lbs.
The 245/45 tire/wheel, (no pic taken) weighed a bit less at 59 lbs.
Question 3: How much clearance is there at the front for a tire bigger than the stock 245/45/20?
There appear to be two tight areas: area A/ at the top of the tire where a bolt connects the upper “A” arm to a “C” shaped vertical arm; and area B/ between the inner edge of the rim and the outer edge of the aforementioned “C” arm.
Area A: See thumbnail pic – with the 245/45 tire there is about ½” of clearance. With the 255/55 tire (sorry no pic) there is about 3/8” of clearance.
Area B: --see next post
DISCLAIMERS:
