1 - 9 of 9 Posts
Hey everyone looking for some wheel help. I have a 2006 300 that I would like to put a staggered set of 20’s on it. Was wondering what width and offset to get a 315/35/20 on the rear? Everything is completely stock, would any modifications need to be made to fit these? Thanks for any help.
Welcome to the forum. I don't know what kind of offset you'd need to put 315/35/20's on the rear or if they'll even fit in the wheel well without rubbing somewhere. Maybe someone else can shed some light on this. I have an 06 300CSRT8 with 11 X 20 in. Foose wheels (don't know the offset) with 275ZR40/20's on the rears and 255ZR40/20's on the front. All four corners are borderline sticking out of the wheel wells. With mine, anything larger in the front or rear would rub and stick out of the wheel wells.
[/QUOTE
T
Thanks for the info, I might be doing some wishful thinking that I can fit those tires on it, but it never hurts to ask or see what other people are doing...if I make it happen I’ll definitely post some pics. Thanks again!
I had 315/35 Michelin PS4 on OEM 20x10 widened SRT wheels with a 10mm spacer and extended lugs.
I went more recently to a 305/35 PS4S for a bit more grip.
The fitment was just inboard of the fender.
Thanks for the info and the pics! That looks great!! What about your suspension?
Thank you. The rear just has a mild lowering spring with Bilstein HD shocks and struts and oem Charger Srt springs up front.
Bm-srt, with your modified stock wheels, your exposure outside the wheel wells looks almost like mine, front and rear so, obviously, with the correct offset you can put the larger tires on it. My Foose wheels have a completely different offset, with a pretty deep dish that pushes the tires outward farther. Looks like a lot of your tire goes inward.
Dont know how much this will help but i have 22x10 1/2 with a +25 offset on 35s for the rear with about a 1 1/2 in drop... dampers set at medium with ST suspensions coilover kit. Rubbing only occurs occasionally when i hit highway bridge bumps at speeds in excess of 65+
174347
174348
174349
This is a pic when a 90 year old woman swiped my car
174351
1 - 9 of 9 Posts
