Stalling and bucking random speeds code U0100 & P0700
65 views 3 replies 2 participants last post by  Trouble1048184
#1 · (Edited)
Does any1 kno what would cause all this? Its alr had a pcm change (supposedly) before ive changed fuel injectors, intake, sensors, fuel pump and sending unit, throttle body X2, spark plugs and coils, Trans plug.
Ive taken it to shops and dealers and they are even confused (granted this was before all these codes) They even told me if I figured out the problem to let them know
It first started off as it dieing then about 2weeks to a month before it gave me a camshaft sensor code ive since replaced it 2 times once with a mopar 1 with a offbrand no diffrence
What ive noticed is when my car bucks/jerks the headlights will dim and if my radio is on p6 or wtv number it has static when gaining rpm and even downshifting my battery on my evic menu shows it drop to 12.2-12.5v when it tries to die at higher speeds
(Mind u I replaced all that before it gave me all those codes gave me them like prob 3-4 month after this issue started)
#3 ·
Hey @Trouble1048184,
That sounds like a seriously frustrating issue, especially after replacing so many parts. I noticed you mentioned the headlights dimming and the battery voltage dropping right when it starts to buck and jerk. Have you had a chance to check the main engine and body ground straps for corrosion or looseness? Sometimes a bad ground can cause all sorts of wild electrical gremlins like you're describing, and sharing what you find might help the community narrow it down.
#4 ·
Yes i have ive checked and cleaned all grounds or atleast most them they weren't bad with corrosion js looked like normal age (for the engine) couldn't find find any locationa for body grounds except the 1 under the steering wheel they were all tight so ngl its getting confusing now
I have also noticed my pcm milage says 205k and my dash milage shows 217043
