Hi all I have a 2006 crd that won’t start it has no injector pulse iv changed the filter if I put aerostart in the intake it will start the only code it comes up with is p087. Doesn’t make a difference hot or cold
P0087 is "Fuel rail pressure too low".
Assuming you have fuel in the tank, it could be the electric pump has failed.
I have replaced the in tank fuel pump already I don’t it’s strange how I got no injector pulse but with aerostart turns over that bit faster and seems to trigger the injector pulse and fires strait up. Also noticed the security light built into radio keeps flashing while trying to start. Do you no if that’s normal
2006 300C CRD
Currently having the same issue with my 2006 CRD, we have replaced the glowplugs even updated the ECU but its still struggling to turn over.
