1 - 9 of 9 Posts
I have a 2007 SRT 8
One day I turn the key off and my seat and steering column didn’t go all the way back like it used to any ideas on what the problem could be. I don’t know if it’s a fuse or what else it could be
1. Does the seat still move when you use the buttons on the side?
2. Similar on the Steering column
Worth checking the wiring harness under the seat is still fully attached
If you change/ set you drivers sear #2 settings, does your car “remember” those settings for setting #1 and #2?
Do you have your original owner’s manual?
I do not have the original owners manual. But it’s more than just the seat it is the steering wheel goes in and down my she goes all the way back all that does not work anymore and I don’t know why it’s weird
A few more questions:
1. Have you switched over the key for a different one?
2. Have you tried resetting the seat: https://www.300cforums.com/threads/drivers-seat-not-moving-back-when-key-removed-moved.75339/
3. Have you turned the setting in the EVIC off and back on
4. Have you reprogrammed the seat where you like it saved
5. If you're tall or short have you checked the seat has enough free movement back or forwards as per the thread here: https://www.300cforums.com/threads/seat-postion-on-exit-problem.52067/
1 - 9 of 9 Posts
