With all the discussion about brakes, I called over to StopTech yesterday to find out what they had available for our cars. It appears their application for the 300C will be coming out in about 3 weeks. Their sales manager was very helpful and informative with the details for our BBK. He said that a major distrubutor he has in NJ (who has a 300c) will fitting his car with one and would be able to answer any of our technical questions. Below are just some specs for the the 2 wheel caliper application and 4 wheel caliper application. Hope this info helps:
StopTech four wheel Big Brake Upgrade for the 2005 Chrysler 300, 300C. The kit includes ST-40 4-piston front calipers painted red, black, or silver, ST-40 4-piston rear calipers painted red, black, or silver, 7075-T6 billet aluminum caliper mounting brackets, 355x32mm slotted, floating, front AeroRotors, 355x32mm slotted, floating, front AeroRotors, 7075-T6 billet aluminum AeroHats with directional standoffs, StopTech SS (DOT compliant) front and rear brake lines, and Axxis Ultimate front and rear brake pads. Requires 18 inch or larger wheels, however not all 18 inch wheels will fit. Item No. 83-241-4747
StopTech front wheel Big Brake Upgrade for the 2005 Chrysler 300, 300C. The kit includes ST-40 4-piston front calipers painted red, black, or silver, 7075-T6 billet aluminum caliper mounting brackets, 355x32mm slotted, floating, front AeroRotors, 7075-T6 billet aluminum AeroHats with directional standoffs, StopTech SS (DOT compliant) front brake lines, and Axxis Ultimate front brake pads. Requires 18 inch or larger wheels, however not all 18 inch wheels will fit. Please check the wheel fitment chart for your car.
Item No. 83-241-4700
