1 - 8 of 8 Posts
One tire was a little low so I used the factory air pump to top it off. After about two minutes the fuse blew. This was plugged into the outlet in at the bottom of the dash. So I switched to the outlet in the center console and continued without an issue.
Normally I have my radar detector plugged into the outlet within the dash. I've always just left the detector on and as I exit the car the power is cut off to the outlet. A week passes and I replace the blown fuse to the dash outlet. Now for some reason the power is constantly on anytime in the dash outlet.
Mine did that almost every time I used it for the pump. I realized the cig lighter circuit fuse is a lower amp value than the accessory outlet in the console. You could swap in a higher fuse amp value for that location.
But I don't understand the constant power on problem. Is the fuse in securely or is it straddling two positions?
According to the manual and what it was in there both the outlets take a 20 amp fuse. As to the constant on I did check to make sure that the fuse is seated properly and even swapped a few around and still the same problem. Strange.
Pretty dang odd and weird problem ya got there.
I found a 5 amp in that position and thought it was the right one, replacing it each time it blew. When I finally read the manual, I realized I had been duped by making an assumption. Once I put in a 20 amp it took a lot to blow it.
Now I don't need to deal with a slow leak on the passenger side rear so I've pretty much left the little pump alone.
The power outlet (aka LIGHTER-CIGAR) in the dash comes with one fuse that can be installed in either a constant power position or a switched power position. It's fuse #18 (20A) in the trunk's power distribution center. When you pull the current fuse out you will see that the location has three slots to plug a fuse into instead of the usual two. Simply plug the fuse back into the other center/outboard slot pair.
Reactions: BackNBlack
That was it. Thanks for the info, I appreciate it.
1 - 8 of 8 Posts
