well here is the problem i have 2 mtx 9500's and i cant get a box made by the company i was having build it they only make a box that holds one sub that is 25 1/2 inches wide and 15 5/8 tall with a depth of 17 7/8. thats the proper specs from mtx.. question is if i buy 2 boxs willl it be ok to put one sub acing the trunk and one facing the cab????
you could go with 2 prebuilt boxes, but be prepared to lose most
of your trunk. Shouldn't be a problem firing one sub forward and
one rearward.
Seems you'd need at least 3.5 cubes to do a ported box for the
9500s, ie, again, taking a lot of the trunk.
Are you sure you need 2 of these? They are quite powerfull and
you'd be heard from quite a distance, if that's what you are looking
for, with only one.
Do a google search for winISD, which is a free program that let's
you model enclosures for a sub based on its thiele-smalls parameters.
That way you can come up with the appropriate box, then it's a matter
of building it, which you can do yourself.
You can also try contacting a local audio shop in your area to build what
you need.
I don't want to sound like a commercial, but you can also contact
the folks at elemental designs. You can actually order a custom
box to be made from their website, and it doesn't look to be too
expensive.
