1 - 8 of 8 Posts
Has anyone 'boxed off' the trunk for subs? I'm sure someone has, if so, can you post some pics? I am thinking of doing and would like to see someone else's work in a 300. I am not an audio expert like some people here, that is why I am looking for examples.
(This is a QUICK DRAFT of what i am thinking of doing)
bigwise...thanks for the reply...I have seen that before...that is an AMAZING install. That's what I am looking for, something classy. Hopefully other people who have done similar installs will post pics/links as well.
(I thought about Wes, but I'm not worthy to even look at his car! :notworthy He is out of my league. I am looking to spend less than 2K possible)
depending on equipment bought you could do it no problem. what brands are you looking to install?
Be carefull with this... unless you have free air speakers it will sound like crap if you don't get the correct air space for the sub's. All depending on which subs you go with they will vary a bunch. Just make sure you are within' the specs for the sub you get, they are usually in the manual, if not you can find that info online. The more airspace, will result in lower bass, the less airspace will result in tighter hitting bass.
Discussion Starter · #7 · (Edited)
bigwise...I have always been a fan of JL. I was thinking about 2 12W3's and 500/1 amp. To be honest, I haven't thought that much about it yet.
I just put the pic together real quick, I didn't put too much thought into what I wanted. I really like your setup. Your subs are essentially 'boxed off' right? Is that enclosure air tight?
yeah, they're sealed off. that's the way i would recommend. 2 12w3's and a 500/1 would be cool.
1 - 8 of 8 Posts
