New member - first post.
I installed an Alpine Amp and Sub woofer in my 2011 Chrysler 300 Limited with a LOC which switches the amp off automatically. It has worked well and sounds great but if I leave the car parked for a few days it kills the battery. The Chrysler service shop traced it to the amp and it draws 0.5 amps off; and with the power lead disconnected from the battery it draws 0.001 amps.
The LOC is connected to the two rear speakers per the Warez instructions and inputs to the amp remote. I can hear the amp power off whenever the car ignition is off for about 30 seconds.
What can I change to ensure that this battery isn't drained?
Should I not use the remote signal from the LOC to control the amp; and instead connect a remote signal from the stock stereo? Should I put a relay in the take the remote signal and kill the power supply to the amp? What do you recommend??
