***I wanted to know if the Superchips Tuner will actually give us any gains on the dang intakes that we've purchased or is it an over all improvement due to a leaner mixture and timing adjustment?
As for shift points, I thought that Chrysler would already set us at the best shift points. I'm really confused as to what this item will do. Please help.
Thanks,
Bruce****
The perameters that we are going to change will be the AFR (air fuel/ratio)
advancing timing and a more lean mixture. This is a old hot rodder trick. We generally make 10% more HP and 13%+torque on 91 or better octane fuel with the way we tune. This will improve the performance thoughout the thottle band right off idle to red line. We do give the option to raise the rpm limiter and top speed governers. In the neighborhood of 240+MPH and 200-300rpms depending on application. This will not harm the engine as long as you do not abuse it. As for the transmission we usually firm up the shifts and raise the MPH in which the trans will shift based on throttle position. 1/2 or more in the throttle and it will extend the MPH up to 10MPH more in each gear 1-2,2-3,3-4.
On the Chrysler products there is alot of torque managment in the computer. With our tuning we turn off most of the torque managment. Throttle sensitivity is dramatically better. More of a 1-1 feel. We also give you the ability to use our product to access your computers diagnostics to check for and to clear DTC's (diagnostic trouble codes) by yourself without having to pay someone to use a expensive scan tool that they are making it harder for the normal joes out there trying to fix or diagnois there vehicles.
SO I hope this helps. If you have any questions feel free to drop me a email or call.
Ron
:slomo:
[email protected]
1-888-227-2447
