Rogue is 100% right... sorry I didn't listen to you before
I still went ahead and decided to try the 6x9 with the stock amp... hmmm a no no
it sounds the same as before...
I went with the Pioneer 2 way
http://www.pioneerelectronics.com/pna/product/detail/0,,2076_4067_35015,00.html
put them against any set that cost $300 and you can not tell the difference... I had great results with the 6x8 i put in my Mazda so that is why I decided to go with this ones for the 300.... but the stock 380watts amp that came with the car does not even move them
I still have the punch 400x4 that I had in the mazda... for now I just have no clue how Im gonna install it since I have the Nav... rogue, any ideas? did you have the nav as well??
well, msrp says $220, i got mine locally for $120... Im sure you might do even better online... good luck...
rogue, how much dynamat (or damping material) did you use for your trunk? i ended up using 40 square feet
and there was still some empty spots.
