1 - 20 of 573 Posts
Here is the solution we have been waiting for someone to come up with,
Credit to Alex Crow an independent Mercedes specialist and member of the Mercedes Benz owners forum.
The M55 is the same 3 wire motor fitted to the om642 CRD engine,
This appears to be the contents of the emulator but only costs coppers.
Inlet port shut off motor delete (CDI2)
A popular mod now, is to disable the inlet port shut off flaps, particularly on 270 CDI (612) engines.
This is usually done because of damage to the flaps from wear and tear, accelerated by EGR gasses.
It is possible to replace the entire manifold, but at significant cost, and some of these cars are old and unloved now!
Even if the manifold is changed, problems can still occur with the actuator motors (M55) jamming and signaling faults to the ECU.
So, how to do without the system...
To remove the flaps is simple, but leaves big holes in the intake manifold.
To plug these holes, I cut short sections of 16mm threaded bar, tap threads in the holes, fit the plugs with superglue, and finally drill and lockwire them for good luck.
With me so far?
But we still have a problem, if the motor is removed, a fault code will be logged, stating 'M55 inlet port shutoff motor signal wire resistance too high'.
Yes, the motor can be left in place and connected to the loom, and if working there will be no fault code.
However, as is often the case, the motor may have heavily worn gears, and frequently jam.
This will log a different code - 'M55 inlet port shutoff motor signals fault through ground keying', which simply means the integrated circuitry in the motor has seen that its mechanism is jamming, and has signalled a fault to the ECU by temporarily grounding out the signal wire.
So, if the motor is worn and jamming, we have a problem, but we do not want to replace it with a new one, especially now there are no flaps fitted.
Getting there now...
So, to cut to the chase, all we need to do to avoid logging fault codes, is wire in a resistor between the signal (PWM) wire and the 12v wire to the M55 motor.I have found that values from 1k to 10k ohms work - 20k ohms is too high.
I have opted for 4.7k ohms on my testbed, and so far all is well - no codes being logged.
I should add that you can buy these mods on ebay http://www.ebay.co.uk/itm/Inlet-port...item1e6a7d237e , but they are rather more expensive than a 4.7k ohm resistor...
Edit..
I have now carried out the mod..pics at post no 49.
Thanks for flagging this up.
If anyone cares to refer to a previous very long post about this very same issue they will see that I was certain there was a solution involving simple resistors rather than paying silly money for an emulator.
Well done and thanks for the info.
Jack
AH! But does it have much inside,or is it a bluff, we won't know untill someone opens one up,
it may be like some of the cheap power boxes with a resistor encased in black mastic.
2006 CRD Touring
Its just as some of us surmised, even simpler than the two resistor solution that was originally proposed. It does seem a logical solution as all the ECU appears to be looking for is a voltage and current source that would indicate all is well in the swirl motor input. There is obviously no check on motor drive current, which is consistent with the workshop manual info. Zero impedance to ground or an open circuit are the fault conditions to be avoided. A small 4.7K resistor connected between the PWM signal wire and 12v would dissipate such a small amount of energy that it could probably be incorporated directly into the wiring loom without the need for any separate enclosure.
Somebody on one of the Audi forums opened up one of these boxes and found a microchip. I looked up the chip reference number and discovered it was an Ethernet interface (!!!). I suspected that the active component was probably just an internal resistor, but designed to fool the unwary.
that'll be for the exhaust cat 5
The Resistor does work...forget swirl motors
With me so far?
I had a nip to Maplins today and got a 4.7k ohm resistor 26p..well it is connected and the car runs as normal..no errors and no eml...I will leave it connected and see how it performs long term...
My swirl motor hasn't failed but theres no point in reconnecting if it's running ok.:smile::smile::arms:
I Think this solution would probably work for disabling the Egr valve also..I may give it a try next.
The thing is if the egr valve is blanked it still has to be disabled or overridden in the Pcm to prevent a error code and possible safe mode...You don't need to blank it if you disable in the pcm...it is closed by default.
Discussion Starter · #13 ·
Ha Ha...funny.
2006 CRD Touring
I suspect 1/4 watt would do.
According to Ohms Law, P=(V x V)/R. So if V=12V and R=4,700 then P=31 milliwatts, so 1/4 watt is more than adequate.
If you wanted to build in some redundancy, you could parallel a couple of 8.2K resistors to achieve 4.1K, so that if one were to go open circuit, the other should still do the job.
Variable Resistor.
Sorry not wanting to start a new thread on this there will end up to many but;-
Don't know if its been mentioned before but, the Turbo vanes alter under load on this turbo.
So I reckon the Resistor would have to be variable.
Turbo vanes must alter with speed or measured pressure, surely the vanes would stay at a certain angle that related to given speed/pressure for a smooth operation.
Discussion Starter · #16 ·
Update....I did 25 miles today, my normal mixed town/ dual carriageway run, The car is running perfect and recording it's normal 36+ mpg...so why bother with a swirl motor?
Reactions: devilmaycare
thats what I've been saying for years,you don't need it or the flaps
Get in!
Is your EGR blocked off Al?
That's brilliant MPG your getting.:cool3:
Why would the position of the variable geometry turbo be dependant on the position of the swirl motor?
The swirl motor(amongst other things) determine where the actuator for the VV should be,it's been proven on here with that vid of the tugboat clock...lol...knick the signal off the swirl to make the VV work
1 - 20 of 573 Posts
