1 - 3 of 3 Posts
Can anyone help I have a 300c and the red lightning bolt keeps flashing when I stop and restart the engine it goes off but comes back on again after a short distance
The "red lightning bolt" is for the Electronic Throttle Control. You may need to have a dealer or someone with a DRBIII Starscan system to determine what the issue is.
Most likely problem is a Swirl Motor failing.
Ideally you need a code reader to check for any error code , but for what it costs you could take a guess and buy a 4.7k resistor from maplins or some other supplier, fit it, and see how it goes.
See the many previous posts about Swirl motor failures and how to fit resistor. Buy a 4.7k 1 watt or even higher wattage because the lower wattage resistors leads are a bit small.
jack
1 - 3 of 3 Posts
