Hey everyone, i have 22's on my 06 300CSRT8 and the rims are not equipped with pressure sensors, so i was wondering if anyone knows how to disconnect a wire, or something and where, that could possibly stop the system from beeping every 30 Seconds.
the TPMS is part of the WIRELESS CONTROL MODULE, which controls your remote key entree and can not just be disconnect by a wire
TPMS can i make it work whis costom rims like 22/9 265/35/22 front and 22/10.5 295/30/22 back like to have it working on my car
sorry for my bad english
You can get the TPMS to work with any wheel...
here's some solution for multi-piece wheels:
http://www.300cforums.com/forums/wh...-aftermarket-wheels-no-drilling-required.html
For most rims, just transfer the sensor from the old wheel, or order new OEM TPMS sensors for your country model from the dealer and install in the normal valve stem hole.
If all else fails, and you can't use OEM or the link above... the straps in the link above will work with any wheel, but are a bit more cumbersome.
thx that helps a lot
