I just performed the steps to get the seatbelt warning chime to stop on my 300C SRT-8.
To my surprise it also defeats the seatbelt warning light.
Another surprise that it also defeated the annoying tire pressure light that keeps coming on due to my winter tires not having the presssure sending devices.
All in all, a good thing!
How did you perform the 2 operations, I want to do the same on my 06 300c
Let me know thanks
Wow, I only got mine to stop the chime but my light still stays on if my belt is not buckled. however I do make a honest effort to buckle up one for safety and the second it's the law in NY.
Well... the warnings ligths came back on the next time I drove the car. Sorry to mislead.
From The cars Manual:
"Note:
The following steps must occur within the first 60 seconds of the ignition switch being turned to the ON or START position. DaimlerChrysler does not recommend deactivating the Enhanced Warning System (Belt Alert)."
1.Turn the ignition switch to the LOCK position and buckle the driver's seat belt.
2.Start the engine & wait for the Seat Belt Warning Light to turn off.
3.Within 60 seconds of starting the vehicle, unbuckle & then re-buckle the driver's belt at least three times within 10 seconds, ending with the seat belt buckled.
"Note:
Watch for the Seat Belt Warning Light to turn on while unbuckling and off while re-buckling the seat belt. It may be necessary to retract the seat belt."
4. Turn off the engine. A single chime will sound to signify that you have successfully completed the programming.
The Enhanced Warning System (Belt Alert) can be reactivated by repeating this procedure.
"Note:
Although the Enhanced Warning System (Belt Alert) has been deactivated, the Seat Belt Warning Light will continue to illuminate while the driver's seat belt remains unbuckled."
