1 - 3 of 3 Posts
HI ALL
NEW TO THE FORUM!
MY O6 HAS 255s IN THE FRONT AND 245s IN THE REAR AND I WUOLD LIKE TO SWAP THEM.
CAN I SWAP RIM WITH TIRE FRONT TO BACK OR DOES THE WHEEL HAVE TO STAY IN ITS LOCATION BECAUSE OF THE AIR SENSORS?
:pat:
swapping the tires to different locations does not effect the tps monitors. (rotating tires) the tps system will adjust itself, for whatever wheel is on whatever corner. but you state you have the 255 up front, someone must have swapped them before. its should be 245 front, 255 rear. u dont want a smaller tire in the rear.
Hey kr, Thanks For The Reply And The Info.......i Always Thought The Car Would Look/ride Better With The Wider Tires In The Back!
Will Swap Them Today.
1 - 3 of 3 Posts
