Alright, so as some people have made note, the transfer case in our vehicles seems to be the weak spot in our drivetrain. Since no one has stepped up in the aftermarket to take care of this need (at least, not to my knowledge I've began some creative research into alternative solutions. Through some service manuals and part number guides, I've come up with a solution that may just be viable, thanks to our friends at Mercedes, unless I'm drastically overlooking something. Mercedes has a relatively solid 4Matic AWD system, and their transfer case is pretty solid. This system can be found in C class vehicles, as can the Nag1 transmission. I'm sure by now you can see where this is going - I want a 4Matic transfer case in my vehicle.
Now the important question - will this work? If in theory it does, I'm willing to put the investment in and test it out. I cannot see an issue with the computer reading it, and the physical connection should be ok, since another Nag1 connects to it no issue. If this in theory works, this also brings to light the possibility of moving a 7G Tronic transmission into our cars, but that's a whole other animal, since then you're moving over a PCM and TCM to read gears (doesn't mean it's not possible, but again, that's another battle). So, will the 4Matic transfer case work in our cars? If not, what other solutions to the transfer case are there? I ask as a rather large overhaul has started, and figure transfer of power to the ground is the best place to start.
