1 - 11 of 11 Posts
We have 13,600 miles on our 2005 300C. Absolutely no issues until last Friday and we had what apprears to be a transmission fluid leak. Over the weekend it looks like about 4 oz. of fluid leaked out. Looks like it leaks overnight as short term stops don't appear to leak.
Took it to the dealer today to get diagnosis in the morning.
Just wondered if anyone else has seen a similar problem?
my brothers transmission has developed a leak as well.
i was pissed to find out i couldnt check a dip stick to see how much fluid leaked, or to re-fill it.
Mine did it around 12k miles...O-ring TSB. Easy fix and it wasn't down much if any at all.
ONE QUESTION; are you sure it's the transmission? Just could be the power steering. Just a thought; check and see where the location is in relationship to the lines.
Transleak
Yes, had mine in the shop about 2 weeks ago to have o-rings replaced. I had 11k miles on mine at the time. Stopped leak but makes me wonder why they failed so soon.
leak
Yes it happened to mine at 19,000 miles went away for a week and came back and all over the floor.They towed it in and fixed it.
odd though.
Just out of curiousity, have any of you with leaks had the TSB done for the transmission shudder (the drain/refill/x3 procedure) prior to the leakage?
06 Awd Trans Oil Leak
joey said:
My transmission also developed a leak. It was fixed under TSB 21-002-05
mine is an 06 and the o rings where the electrical connection goes into the tranny started to leak. this tsb is for an 05. i have 12000 miles. any body else with an 06 experience this problem?
bigalsdad
I also have the leak on my 06' at 8,800 miles...
and the other SRT8's that I know where even less...
No biggy...
TSB on it...
Tranny Leak
Mine started leaking at about 11,000 miles. TSB changed out the o-ring, done. As they have them in stock, and so many people are chiming in saying theirs leaks, it's probably a case of when not if it will leak.
Dan
1 - 11 of 11 Posts
