1 - 3 of 3 Posts
I have a 2005 Chrysler 300c and my transmission is having issues. When I drive it it goes into first goes into second before it jumps into 3rd gear the RPM JUMPS then it catches an the RPM DROPS AND IT JERKS IF I TAP THE GAS AFTER GOING THREW THE GEARS ⚙ TRYING TO MERGE INTO THE NEXT LANE AS A PASSING VEHICLE I HAVE CODE p0038 on my Chrysler 300c 2005
That is an O2 sensor code. It could be a bad sensor, shorted lead, a ground problem, or an issue with the PCM, like a corroded or loose connector or damaged wiring.
What kind of scantool are you using?
Start by checking the transmission fluid level using the procedure outlined in the Factory Service Manual. You may also want to consider a fluid/filter change so you can inspect the contents of the pan, especially if it hasn't been serviced for a while. To check for transmission codes, you'll need a scantool that has the capability to check transmission codes....not all scanners can do it.
1 - 3 of 3 Posts
