When my STR-8 6.1 is cold it slips just a small amount as I pull away . Looking at the paper work that came with the car I don't think its ever had a gearbox service , its done about 77,000 miles. Would an oil & filter change fix this ? Is this the same auto-box thats in the S Class Merc & what colour is the oil ? As I have a mate that works in a Mrec Dealership and may be able to slip it in on a Saturday and do it for a drink ! But they not want to take it in if it turns out to be the wrong box and they not have the parts to do it and get it out before the boss gets in !!! Thanks PAT
the NAG1 transmission, also called WA580 (or 5G-Tronic / 722.6), was a MB item, also used in Vito, Sprinter & severral MB cars. Its a bit tricky to do properly yourself (you need to measure temperatures & fill according to a sliding scale based on that), so if you can get a dealer at El Cheapo prices, its a good idea - the box is still used in their high output cars, eg AMG S65 as it has a capacity of 756 Ft/Lbs. A variation was also put into the SLR McLaren....unfortunalely for the boasting, SsangYong also use it
1996–1999 Mercedes-Benz W140
2000-2005 Mercedes-Benz W220
2006–Present Mercedes-Benz W221 (V12 Models only)
1997-2002 Mercedes-Benz W210
2002-2004 Mercedes-Benz W211
1997-2000 Mercedes-Benz W202
2000-2004 Mercedes-Benz W203
1998-2005 Mercedes-Benz W163
1997-2004 Mercedes-Benz W168
2004–Present Mercedes-Benz W169
2005–Present Mercedes-Benz B-Class
1998-2005 Mercedes-Benz R170
1990-2001 Mercedes-Benz R129
2001–Present Mercedes-Benz R230 (V12 Model and Earlier, up to 2005)
1998-2002 Mercedes-Benz W208
2003-2005 Mercedes-Benz W209
2000-2006 Mercedes-Benz C215 (V12 Models only)
2007–Present Mercedes-Benz C216 (V12 Models only)
1996–Present Mercedes-Benz W463 (AMG Models only)
2005-2009 Mercedes-Benz SLR
2002–Present Maybach 57 and 62
1998-2002 Jaguar X308 (Supercharged models only)
1998-2002 Jaguar XK (X100) (Supercharged models only)
2004–Present Ssangyong Rexton
2006–Present Ssangyong Kyron
2005–Present Ssangyong Rodius
2005-2008 Dodge Magnum- All HEMI applications, all AWD applications and some 3.5L RWD V6 applications, year dependent
2005–Present Chrysler 300- All HEMI applications, all AWD applications and some 3.5L RWD V6 applications, year dependent All pentastar V6 applications
2006–Present Dodge Charger- All HEMI applications, all AWD applications and some 3.5L RWD V6 applications, year dependent,All pentastar V6 applications
2008–Present Dodge Challenger- All HEMI applications, All pentastar V6 applications
2007-2011 Dodge Nitro- 4.0L V6 Applications
2006-2010 Jeep Commander- 3.7L V6 Applications, 3.0L CRD V6 applications
2005–2013 Jeep Grand Cherokee- 3.7L V6 Applications, 3.0L Diesel Applications, SRT8 Applications, all pentastar V6 applications
2011–Present Dodge Durango, 3.6L V6
2011–Present Jeep Wrangler- 2.8L Diesel
2012–Present Jeep Wrangler 3.6L V6
Thanks for that mate, but for pity sake man the bit about the Ssangyoung ( had to look up what it was ) should be hid in a PM:puke::puke:
its a beaut! If it wasnt for being lumbered with an SRT8, I'd be straight to the dealer.........
Have to be odd to be No.1
Its so sad these stylish sexy cars ^^^^ don't make it to Australia, cause it would be off to the dealer for me too.
Then show it off at night where all the boys and their toys meet
Blue top solenoid replacement in our gearboxes has had a small number of adherents over the years....be aware it will make for slightly uncomfortable downshifts (it 'thumps' the new gear ratio into place) - not something you want neccessarily on as daily drive
Checkout the TranZformer too http://www.zautotech.com/tranzformer.html
You need to renew the oil, its degraded so you get the slippage from cold. Topping up won't sort it because its problem from cold. Tale tale sign is oil should smell like ester, when its gonner it turns to brown colour and smells like burnt smell. The Merc oil is pink, cost about tenner for a litre bottle. Don't forget the filter change and seals too. Anyways, heres how
I got the same thing going on. But I'm waiting to change my fluid until I put in a higher stall torque converter, plus i just put it up for the winter. But when I was driving in the cold *20 I was using auto stick to shift until they came up to temp.
remind me not to have that video guy change my gearbox oil :frown:
this guy is annoying, but gets it pretty much right
Discussion Starter #11
Would this on its own be OK to sort the box out with the supercharger ? I only plan on running low boost not going mad . Thanks PAT
personally, I'd be inclined to make a decision....either I want harder shifts that arent adjustable (get bluetops, change the trans fluid at the same time), OR being satisfied with the shifts, just do a fluid change given that that alone will probably remedy the slipping - your mileage puts you smack bang in the 'time to drain' bracket anyway, OR swap the fluid & consider trying a TranZformer if I think the blown car would benefit after fitting it - this last one probably gives you the best of all worlds, you get more adjustability at a cheaper price than AMG bluetops & you can afford to wait until the pain of buying the S/C eases
Most slip problems seem to relate to having the wrong fluid level, or past sell-by date fluid. Its a good idea to swap the fluid anyway if you intend to blow it
Discussion Starter #13
How much oil should it take to refill the trany ? Pan of , new filter, put in 3 1/2 Ltrs of oil !!!!
