1 - 2 of 2 Posts
So these are the codes I recently got, one I'm assuming is the o2 sensor, second not really sure how bad it is.
P0700
P0430
P0430 Causes
  • Faulty oxygen sensor
  • Worn and internally failing catalytic converter
  • Leak in exhaust system
I suspect the sensor has failed but it could also be a bad cat, a dirty or corroded sensor connection or damage to the wiring.
How many miles on your car?
P0700 - The Transmission Control Module (TCM) and Powertrain Control Module (PCM) lost communication.
It can be a momentary glitch but if you clear the code and it comes back, possible causes are:
  • Shorted or open circuit Transmission Control Module - harness connection
  • Faulty Transmission Control Module (TCM) - failed module
  • If you see a leak near the harness connection, the small o-ring there needs to be replaced along with the TCM
1 - 2 of 2 Posts
