Morning, I am new to the forums but i have seen a ton of great advice and I could use some.
I am trying to replace my double din factory radio with the Kenwood DMX706x double din. I did some research and found that I needed the Mastero Rr controller along with the CH1 harness also by maestro. I got everything prepped, watched whatever videos i could find and decided to tackle this project today. I took the factory radio out and found that there are 2 main wire harnesses and a couple of other plugs that I wasn't expecting according to what I could find. Can someone please explain what the large white connector is (I'm guessing all the speakers), the yellow connector and the blue connector (I'm guessing this is either the mic or satellite). The factory radio is the HD model with Nav, Phone and Satellite.
I want to do the same on my 'O6. I would love to put a factory radio back in, but the "refurbished" ones or the "was working fine when I parked it" are almost double what I can buy from Best Buy, Mom & Pop store, or Amazon. When I was at Best Buy they plug kit that had was pretty funky and looked like it would accommodate all of the wires. Good luck !
I seen this on other forums. You can post pics or a simple reply on things you did to your chrysler 300 today. Lets get the ball rolling and start one on here. lets keep posting in here and etc when you do things to your 300, anything.
:drillserg
I loaded the updates on Kingston SD disc as instructed but nothing happens when I insert into car media slot and in the Player/Source the SD option is grayed out. Help
When I bought the car in 2016 I also got the top of the line extended Chrysler Warranty at a price that made me think it would be good deal.
Because it would cover everything on my new car for as long as I owned it.
I just tried to use it because the front door panels are warping and want to get...
Hi I have a Chrysler 300 and have a front passenger door that is permantly locked. On pressing the keys the actuator seems to work with the locking nib button moving up and down but the door refuses to open with the inside and outside handles. So with the door shut how can I remove the panel...
