just thought you guys would like the current list, always best to be informed, btw, I own a durango and though I've heard alot about problems I've never had any myself so you just never know.
Make : CHRYSLER Model : 300 Year : 2005
Service Bulletin Num : 1802704 Date of Bulletin: JUN 21, 2004
NHTSA Item Number: 10008049
Component: ENGINE AND ENGINE COOLING:ENGINE
Summary:
FLASH: ROUGH IDLE OR HIGH RPM ON START OR SPARK KNOCK. *TT
Check to Request Research. Submit below.
Service Bulletin Num : 2302004 Date of Bulletin: JUN 01, 2004
NHTSA Item Number: 10008055
Component: STRUCTURE:BODY:HOOD:HINGE AND ATTACHMENTS
Summary:
HOOD SECONDARY CATCH BINDING. *TT
Service Bulletin Num : 27 Date of Bulletin: JUN 01, 2004
NHTSA Item Number: 10008076
Component: EQUIPMENT:OTHER:LABELS
Summary:
TIRE AND LOADING INFORMATION LABEL INCORRECTLY STATES THAT THE VEHICLE IS EQUIPPED WITH A FULL SIZE SPARE TIRE. SINCE A FULL SIZE SPARE TIRE IS NOT AN AVAILABLE OPTION, ALL INVOLVED VEHICLES ARE EQUIPPED WITH A COMPACT SPARE TIRE. CUSTOMER SATISFACTION NOTIFICATION 27. *TT
Service Bulletin Num : 0802104 Date of Bulletin: MAY 25, 2004
NHTSA Item Number: 10007918
Component: ELECTRICAL SYSTEM
Summary:
ERRONEOUS RADIO DIAGNOSTIC TROUBLE CODE (DTC). *TT
Service Bulletin Num : 0200304 Date of Bulletin: MAY 25, 2004
NHTSA Item Number: 10007925
Component: SUSPENSION
Summary:
VEHICLE LEADS TO THE RIGHT. *TT
Service Bulletin Num : 0801804 Date of Bulletin: MAY 01, 2004
NHTSA Item Number: 10007923
Summary:
WIPER LINKAGE CONTACTS MAP SENSOR WIRING. *TT
Service Bulletin Num : 2100604 Date of Bulletin: APR 27, 2004
NHTSA Item Number: 10006886
Component: POWER TRAIN:AUTOMATIC TRANSMISSION
Summary:
SHUDDER DURING SHIFTS. ALSO DODGE MAGNUM 2005. *TT
Service Bulletin Num : 04009 Date of Bulletin: APR 16, 2004
NHTSA Item Number: 10006905
Component: POWER TRAIN:AUTOMATIC TRANSMISSION:CONTROL MODULE (TCM, PCM)
Summary:
APPROXIMATELY 260 VEHICLES EQUIPPED WITH A 5.7L ENGINE WERE SHIPPED WITH INCORRECT ENGINE SOFTWARE IN THE POWERTRAIN CONTROL MODULE (PCM) THAT RESULTS IN NON-COMPLIANCE. IT WILL BE NECESSARY TO REPLACE THE PCM. *TT
Service Bulletin Num : 0801304 Date of Bulletin: APR 06, 2004
NHTSA Item Number: 10006457
Summary:
RECALIBRATION PROCEDURES REQUIRED AFTER BATTERY DISCONNECT. *TT *MJ
Service Bulletin Num : 0410 Date of Bulletin: APR 01, 2004
NHTSA Item Number: 10006997
Component: POWER TRAIN:AXLE ASSEMBLY
Summary:
REAR AXLE NEW LAUNCH FAST FEEDBACK PROGRAM FOR ALL 2005 CHRYSLER 300 SERIES AND DODGE MAGNUM VEHICLES. *TT
Service Bulletin Num : 0406 Date of Bulletin: APR 01, 2004
NHTSA Item Number: 10007047
Summary:
NEW LAUNCH FAST FEEDBACK ENGINE PROGRAM. WARRANTY PLANNING & ADMINISTRATION BULLETIN. *TT
Service Bulletin Num : 0405 Date of Bulletin: APR 01, 2004
NHTSA Item Number: 10007046
Summary:
NAG1 TRANSMISSION EQUIPPED VEHICLES WILL BE INVOLVED IN A STAR CENTER TRANSMISSION NEW LAUNCH FEEDBACK PROGRAM. WARRANTY PLANNING & ADMINISTRATION BULLETIN. *TT
Service Bulletin Num : 0801204 Date of Bulletin: MAR 23, 2004
NHTSA Item Number: 10006456
Summary:
LOSS OF COMMUNICATION DIAGNOSTIC TROUBLE CODES (DTC'S) SET IN MULTIPLE MODULES DURING NEW VEHICLE PREP/SERVICE. *TT
Service Bulletin Num : 1803303 Date of Bulletin: MAR 02, 2004
NHTSA Item Number: 10003988
Summary:
GENERIC POWER TRAIN CONTROL MODULE (PCM) FLASH PROCEDURE. 2004 DURANGO. *TT *MJ
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
