This is a lot to post, but here goes.
Total of 18 TSB posted here.
You can get them from here.
http://www-odi.nhtsa.dot.gov/cars/problems/tsb/tsbsearch.cfm
Report Date : October 6, 2004 at 09:18 PM
TYPE : VEHICLE
YEAR : 2005
MAKE : CHRYSLER
MODEL : 300
Results : 18
Make : CHRYSLER Model : 300 Year : 2005
Service Bulletin Num :
2100904 Date of Bulletin: JUL 08, 2004
NHTSA Item Number: 10008743
Component: POWER TRAIN:AUTOMATIC TRANSMISSION:CONTROL MODULE (TCM, PCM)
Summary:
FLASH: TRANSMISSION CONTROL MODULE INITIALIZE EGS-52 PROCEDURE. *MJ
Check to Request Research. Submit below.
1803104 Date of Bulletin: JUL 08, 2004
NHTSA Item Number: 10008744
Component: ELECTRICAL SYSTEM
Summary:
FLASH: DRIVEABILITY IMPROVEMENTS MALFUNCTION INDICATOR LAMP (MIL) DIAGNOSTIC TROUBLE CODES P0116, P0139, P0159, P0197, U110B OR U1402. *MJ
29 Date of Bulletin: JUL 01, 2004
NHTSA Item Number: 10008816
Component: VEHICLE SPEED CONTROL
Summary:
CUSTOMER SATISFACTION NOTIFICATION D29. INTERMITTENT LOSS OF THROTTLE CONTROL. REPROGRAM POWERTRAIN CONTROL MODULE (PCM). *TT
1802704 Date of Bulletin: JUN 21, 2004
NHTSA Item Number: 10008049
Component: ENGINE AND ENGINE COOLING:ENGINE
Summary:
FLASH: ROUGH IDLE OR HIGH RPM ON START OR SPARK KNOCK. *TT
0200404 Date of Bulletin: JUN 15, 2004
NHTSA Item Number: 10008424
Component: SUSPENSION
Summary:
SUSPENSION/TOWING/LIFTING DAMAGE. *TT
2302004 Date of Bulletin: JUN 01, 2004
NHTSA Item Number: 10008055
Component: STRUCTURE:BODY:HOOD:HINGE AND ATTACHMENTS
Summary:
HOOD SECONDARY CATCH BINDING. *TT
27 Date of Bulletin: JUN 01, 2004
NHTSA Item Number: 10008076
Component: EQUIPMENT:OTHER:LABELS
Summary:
TIRE AND LOADING INFORMATION LABEL INCORRECTLY STATES THAT THE VEHICLE IS EQUIPPED WITH A FULL SIZE SPARE TIRE. SINCE A FULL SIZE SPARE TIRE IS NOT AN AVAILABLE OPTION, ALL INVOLVED VEHICLES ARE EQUIPPED WITH A COMPACT SPARE TIRE. CUSTOMER SATISFACTION NOTIFICATION 27. *TT
0802104 Date of Bulletin: MAY 25, 2004
NHTSA Item Number: 10007918
Summary:
ERRONEOUS RADIO DIAGNOSTIC TROUBLE CODE (DTC). *TT
0200304 Date of Bulletin: MAY 25, 2004
NHTSA Item Number: 10007925
Summary:
VEHICLE LEADS TO THE RIGHT. *TT
0801804 Date of Bulletin: MAY 01, 2004
NHTSA Item Number: 10007923
Summary:
WIPER LINKAGE CONTACTS MAP SENSOR WIRING. *TT
2100604 Date of Bulletin: APR 27, 2004
NHTSA Item Number: 10006886
Summary:
SHUDDER DURING SHIFTS. ALSO DODGE MAGNUM 2005. *TT
04009 Date of Bulletin: APR 16, 2004
NHTSA Item Number: 10006905
Summary:
APPROXIMATELY 260 VEHICLES EQUIPPED WITH A 5.7L ENGINE WERE SHIPPED WITH INCORRECT ENGINE SOFTWARE IN THE POWERTRAIN CONTROL MODULE (PCM) THAT RESULTS IN NON-COMPLIANCE. IT WILL BE NECESSARY TO REPLACE THE PCM. *TT
0801304 Date of Bulletin: APR 06, 2004
NHTSA Item Number: 10006457
Summary:
RECALIBRATION PROCEDURES REQUIRED AFTER BATTERY DISCONNECT. *TT *MJ
0410 Date of Bulletin: APR 01, 2004
NHTSA Item Number: 10006997
Component: POWER TRAIN:AXLE ASSEMBLY
Summary:
REAR AXLE NEW LAUNCH FAST FEEDBACK PROGRAM FOR ALL 2005 CHRYSLER 300 SERIES AND DODGE MAGNUM VEHICLES. *TT
0406 Date of Bulletin: APR 01, 2004 NHTSA Item Number: 10007047
Summary:
NEW LAUNCH FAST FEEDBACK ENGINE PROGRAM. WARRANTY PLANNING & ADMINISTRATION BULLETIN. *TT
0405 Date of Bulletin: APR 01, 2004
NHTSA Item Number: 10007046
Summary:
NAG1 TRANSMISSION EQUIPPED VEHICLES WILL BE INVOLVED IN A STAR CENTER TRANSMISSION NEW LAUNCH FEEDBACK PROGRAM. WARRANTY PLANNING & ADMINISTRATION BULLETIN. *TT
0801204 Date of Bulletin: MAR 23, 2004
NHTSA Item Number: 10006456
Summary:
LOSS OF COMMUNICATION DIAGNOSTIC TROUBLE CODES (DTC'S) SET IN MULTIPLE MODULES DURING NEW VEHICLE PREP/SERVICE. *TT
1803303 Date of Bulletin: MAR 02, 2004
NHTSA Item Number: 10003988
Summary:
GENERIC POWER TRAIN CONTROL MODULE (PCM) FLASH PROCEDURE. 2004 DURANGO. *TT *MJ
