I couldn't find a thread on TSBs, so I thought I would add this. I was looking at the NHTSA TSB info and reading some of the titles. I think everyone should be familiar with them and/or the site.
There are some important TSBs; i.e. Wrong PCM put in Hemi vehicles, PTTR, etc.
It might make sense to look through them, and to have a dedicated thread.
http://www.nhtsa.dot.gov/
Here's the ones I found
Make : CHRYSLER Model : 300 Year : 2005
Manufacturer : DAIMLERCHRYSLER CORPORATION
Service Bulletin Num : 0803104 Date of Bulletin: SEP 29, 2004
NHTSA Item Number: 10010481
Component: ELECTRICAL SYSTEM
Summary:
INSTRUMENT CLUSTER LANGUAGE (NON-ENGLISH) SELECTION IS NOT SAVED. *TT THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 08-031-04 DATED 09/08/04. *TT
Check to Request Research. Submit below.
Service Bulletin Num : 2303804 Date of Bulletin: SEP 23, 2004
NHTSA Item Number: 10010492
Component: STRUCTURE:BODY
Summary:
REAR DOOR GLASS BINDS. *TT
Service Bulletin Num : 0803204 Date of Bulletin: SEP 22, 2004
NHTSA Item Number: 10010482
Summary:
POOR RADIO RECEPTION. *TT
Service Bulletin Num : 1800904 Date of Bulletin: SEP 13, 2004
NHTSA Item Number: 10010485
Component: POWER TRAIN:AUTOMATIC TRANSMISSION:CONTROL MODULE (TCM, PCM)
Summary:
GENERIC POWERTRAIN CONTROL MODULE (PCM) PROCEDURE. THIS BULLETIN SUPERSEDES BULLETIN 18-009-04 DATED 03/02/2004. *TT
Service Bulletin Num : 38 Date of Bulletin: SEP 01, 2004
NHTSA Item Number: 10010494
Component: EQUIPMENT:OTHER:LABELS
Summary:
EMISSIONS RECALL D38 - VECI LABEL REPLACEMENT. AN INCORRECT VEHICLE EMISSION CONTROL INFORMATION (VECI) LABEL WAS INADVERTENTLY INSTALLED. *TT
Service Bulletin Num : 0424 Date of Bulletin: SEP 01, 2004
NHTSA Item Number: 10010497
Summary:
ALL WHEEL DRIVE A580 TRANSMISSION FAST FEEDBACK PROGRAM. *TT
Don't know how up to date this site is, since it only found three recalls and did not have the radiator bracket recall listed.
NHTSA CAMPAIGN ID Number : 04V333000 Recall Date : JUL 02, 2004
Component: SEAT BELTS:REAR
Potential Number Of Units Affected : 21
Summary:
ON CERTAIN PASSENGER VEHICLES, A SPOT WELDING OPERATION FOR THE REAR FLOORPAN REINFORCEMENT MAY NOT HAVE BEEN PERFORMED.
Consequence:
THIS COULD CAUSE THE REAR SEAT BELT ANCHORS AND/OR THE CHILD SEAT ANCHORS TO SEPARATE IN CERTAIN CRASH CONDITIONS, WHICH CAN INCREASE THE RISK OF INJURY TO REAR SEAT PASSENGERS.
Remedy:
DEALERS WILL INSPECT THE REAR FLOORPAN REINFORCEMENT FOR MISSING WELDS AND INSTALL STRUCTURAL RIVETS IF NECESSARY. OWNER NOTIFICATION BEGAN ON JULY 6, 2004. OWNERS SHOULD CONTACT DAIMLERCHRYSLER AT 1-800-853-1403.
Notes:
DAIMLERCHRYSLER RECALL NO. D21. OWNERS CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-888-DASH 2-DOT (1-888-327-4236).
NHTSA CAMPAIGN ID Number : 04V334000 Recall Date : JUL 02, 2004
Component: ELECTRICAL SYSTEM:BATTERY:CABLES
Potential Number Of Units Affected : 20060
Summary:
ON CERTAIN PASSENGER VEHICLES, THE BATTERY CABLE FASTENERS AT THE BULKHEAD STUD MAY NOT HAVE BEEN PROPERLY TIGHTENED.
Consequence:
A LOOSE FASTENER CAN CAUSE AN INSTRUMENT PANEL FIRE.
Remedy:
DEALERS WILL TIGHTEN THE BULKHEAD STUD BATTERY CABLE FASTENERS TO THE PROPER SPECIFICATION. OWNER NOTIFICATION BEGAN ON JULY 6, 2004. OWNERS SHOULD CONTACT DAIMLERCHRYSLER AT 1-800-853-1403.
Notes:
DAIMLERCHRYSLER RECALL NO. D28. CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-888-DASH 2-DOT (1-888-327-4236).
NHTSA CAMPAIGN ID Number : 04V335000 Recall Date : JUL 02, 2004
Component: SEAT BELTS:FRONT
Potential Number Of Units Affected : 12211
Summary:
ON CERTAIN PASSENGER VEHICLES, THE FRONT SHOULDER BELT ADJUSTABLE TURNING LOOP (ATL) BOLTS MAY NOT HAVE BEEN PROPERLY TIGHTENED.
Consequence:
THIS COULD CAUSE SHOULDER BELT SEPARATION IN CERTAIN CRASH CONDITIONS, WHICH CAN INCREASE THE RISK OF INJURY TO FRONT SEAT OCCUPANTS.
Remedy:
DEALERS WILL TIGHTEN THE SHOULDER BELT ADJUSTER TURNING LOOP BOLTS TO THE PROPER SPECIFICATION. OWNER NOTIFICATION BEGAN ON JULY 6, 2004. OWNERS SHOULD CONTACT DAIMLERCHRYSLER AT 1-800-853-1403.
Notes:
DAIMLERCHRYSLER RECALL NO. D30. CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-888-DASH 2-DOT (1-888-327-4236).
