1 - 3 of 3 Posts
Hello all.
I’ve had a year 2006 300c diesel with the standard wheels and tyres. Smaller than the SRT model in diameter and probably higher side wall tyres. I covered 118,00 miles in that car and throughout its tyre changes the car made zero tyre noise.
About 8 months ago I got a beautiful year 2010 300c SRT diesel with the 20” x 245/45 tyres. It “sings” like a right bugger, I’m thinking from the tyres.
I changed the tyres for the lowest noise rating ones I could get but it still “sings”. Maybe less now.
Is this a “feature” common to these larger diameter tyres with the low profile on this car?
I’ve posted in this section because it’s not diesel specific I’m thinking.
Thank you for any input here.
Regards.
Rich.
The stock 20" tires on my 2020 don't do that. I think such noise depends upon the tread pattern and not so much the tire diameter.
Welcome to the forum. Obviously, different brand/style tires will generate different sounds under different circumstances. A lower profile tire will not necessarily make more noise, but it will give you a harsher ride. Since you changed the tires and you still have the noise, have you checked anything else.....wheel bearings, drive shaft, differential, something rubbing somewhere, etc?
1 - 3 of 3 Posts
