U connect was working fine, and then one day boom. At times I can't answer my phone even when connected to bluetooth/UConnect in the car, if I step out of the car I can answer the phone. The connection now in the car is horrible with tons of static when previously it was crystal clear.
Any suggestions.
The only thing I might try is to delete and Re-Pair the phone. I'm no expert but it kinda sounds like it might be your phone, not the car. Good Luck!
I was going to suggest the same thing. Bluetooth is pretty standard on most cell phones nowadays, you should be able to pair up a second phone (from a friend or relative) and test it out. I think you can pair up to 8 phones with Uconnect system (only one can be active simulaneously though). Good Luck
You can also try to reset the UConnect by pressing both buttons at the same time for I think 10 seconds.
Bernie
thanks guys, I will try that
