I recently installed the UAS bags on my car. During the install I tried to run the bottom bag bolt up and it seems the washer is too small. So I ran the bolt up as far as I could.
The issue is, now when I drive down the road the washer is bouncing and jingling with every bump.
Who else has has this issue and what did you do to resolve it?
From what I have seen with the parts I installed was that the threaded section of the bolt that holds it in the lower arm is too short. You can use extra washers, a spacer or even a large nut that will take up the extra space. With the spacer you apply pressure to the washer as you tighten the nut. hope that helps.
