I have a 2019 300 with the Uconnect 4C. Was wondering if anyone knows how to get to the engineering menu. The dealer menu just has 3 options. Would like to restore to factory defaults
So what is the right way? Bob.That's too easy as I saw the procedure on one of many youtube vids. Unfortunately, I found out that none of the 'soft reset' recommendations worked so I phoned UConnect to get the correct procedure for my car. You should probably do the same.
Keep in mind my 2020 300s is equipped with the Panasonic - Alpine UConnect 8.4 w/Nav system.So what is the right way? Bob.
OK. Thanks, Bob.Keep in mind my 2020 300s is equipped with the Panasonic - Alpine UConnect 8.4 w/Nav system.
ACC on - Doors closed - UConnect Off
Depress the VR and Green button simultaneously for at least 30 seconds
Turn car completely off - wait for all systems to shut down, usually takes several seconds
Open driver's door for at least 30 seconds before reclosing
UConnect soft reset complete.
Hard Reset is in the menu - I've never had to use it. I was frustrated recently with the voice command function on both of my vehicles - Navigation couldn't find the street. Turned out I was mispronouncing the name.
