VTSS Indication - During the sixteen second VTSS arming function, the cluster will flash the security indicator
on and off repeatedly at a steady, fast rate to indicate that the VTSS is in the process of arming. Following
successful VTSS arming, the cluster flashes the security indicator on and off continuously at a slower rate to
indicate that the VTSS is armed. The security indicator continues flashing at the slower rate until the VTSS is
disarmed or triggered. If the VTSS has alarmed and rearmed, the cluster will flash the security indicator at a
steady, slow rate for about thirty seconds after the VTSS is disarmed.
The instrument cluster circuitry controls the security indicator whenever the ignition switch is in the Off position and
the VTSS is arming, armed, or alarming. Whenever the ignition switch is in the On or Start positions, the SKREEM
performs a self-test to decide whether the SKIS is in good operating condition and whether a valid key is present in
the ignition lock cylinder. The SKREEM then sends the proper lamp-on or lamp-off messages to the instrument
cluster. For further diagnosis of the security indicator or the instrument cluster circuitry that controls the indicator,
(Refer to 8 - ELECTRICAL/INSTRUMENT CLUSTER - DIAGNOSIS AND TESTING). If the instrument cluster
flashes the security indicator upon ignition On, or turns on the security indicator solid after the bulb test, it indicates
that a SKIS malfunction has occurred or that the SKIS is inoperative. The Security indicator is serviced with the
instrument cluster.
