When I did my routine inspection of my 08 300lx the other day I noticed some pink/orange fluid. I whipped it with a cloth clean and did a test drive, when I checked it again I saw more fluid. One end of the whoes goes to the radiator and the other I think might go to engine although I am not sure. My coolant is also very low and its the same color as this fluid. pink/orange ish.
I am not a mechanic, but I do my own oil changes. I am also not working right now only a little big when I get side jobs. So I would like be able to fix this myself with your help. Would be as simple as removing the bolts and replacing the gasket? My lx has 51K miles
coolant air bleeder installation tips
Hey chrysler 2.7l owners save your bucks dealer wanted well over $500 i did mines myself in about a 1hrs time but only if your gentle and handy. The intake does not have to come off theres a 10mm screw @ the back of the right head holding that pipe running under the intake,take that a loose then take the coolant air bleeder off once all screws are off take a big screwdriver and gentle rock the top hose connector pipe off then reverse the same to install. Trust me to me no time
