Just bought a new 300C 3.6L that I thought was a flex fuel vehicle, and after running one tank of regular, and one tank of E-85, and filling up again today with E-85, the check engine light comes on, I do a little research, and find it is NOT a flex fuel. Seems like I cannot siphon out the gas because of a filter, so does anyone have a suggestion as to how to proceed?
I would have thought the dealer had a duty of care to explain PROPERLY things like that to new owners. Perhaps contact them or Chrysler Customer Care.
You will have to drain the tank. You don't want to punch through that filter.
Drop the tank and drain it.
Have to be odd to be No.1
I'd be tempted to see if the dealer would do it first. It's worth putting to the dealer what Piggy said and see what happens. No harm in asking
Ouch, so what happened? Did you contact the dealer, is everything OK?
Probably to late but found this in the Manual.
If a Non-FFV vehicle is inadvertently fueled with E-85
fuel, the engine will have some or all of these symptoms:
• operate in a lean mode
• OBD II “Malfunction Indicator Light” on
• poor engine performance
• poor cold start and cold driveability
• increased risk for fuel system component corrosion
To fix a Non-FFV vehicle inadvertently fueled once with
E-85 perform the following:
• change the engine oil and oil filter
• disconnect and reconnect the battery
• drain the fuel tank (see your authorized dealer)
More extensive repairs will be required for prolonged
exposure to E-85 fuel.
