ok for us non mechanical car nuts what information can I get off the VIN number. Where can I find the build date on my ride. Just for inquiring minds.
If you look inside the drivers door, there's a sticker on the door itself. Below the bar code you'll see six numbers. This is the build date and time your car was built. Mine is 030721, which means it was built March 7th at 9 PM.IceMan1959 said:ok for us non mechanical car nuts what information can I get off the VIN number. Where can I find the build date on my ride. Just for inquiring minds.
Now I am truly confused -- not that it takes a lot to do that. Rambit, below the bar code on my CSRT-8 is a line starting MDH 062423. Does that mean that the car was built on June 24th 2006 at 11 P.M.? If that is what it means, then what does it mean at the top of the label where is says Date of MFG 7-05??Rambit said:If you look inside the drivers door, there's a sticker on the door itself. Below the bar code you'll see six numbers. This is the build date and time your car was built. Mine is 030721, which means it was built March 7th at 9 PM.
Rambit
Calling ResumeSpeed. He maybe able to answer both of your questions definitivly. From the six digits you are correct on the build date though. Why don't you PM RS for answers?Dante said:Now I am truly confused -- not that it takes a lot to do that. Rambit, below the bar code on my CSRT-8 is a line starting MDH 062423. Does that mean that the car was built on June 24th 2006 at 11 P.M.? If that is what it means, then what does it mean at the top of the label where is says Date of MFG 7-05??
Also, where do I get all those neat statistics such as the 25 of 225 cars built?
Dante!
jjs said:First of all, it cannot be 2006.
Perhaps the difference is that it was put into the build process in the last week of June, but was actually a completed manufactured item in July.
