I having some trouble with my car. I have developed the violent front end shake when applying the brakes it is not consistent and only happens if I get on the brakes hard. Shaking goes away when the vehicle slows down. I have replaced brake pads, rotors, control arms ball joint steering rack, and outer tie rods. I am in the process of replacing front end bushing with poly bushing. I only got the tension struts done and we do the lower control next week. Anyway, I toke on the freeway after replacing tension struts bushing car has never shaken the hard a day in its life. My last effort is to finish replacing the front end bushing with poly bushing and rebuild front calipers because I notice a hard pull to the right when braking. I am spinning my wells on the one tires are new and balance rims are not bent I switched them all out with ones off a brand new 300 just to see if a bent rim was the issue
PLEASE HELP I AM JUST THROWING MONEY AT THIS Point
