I've compiled a list of the necessary files for the US map updates, but I don't have any information from the other map regions.
I'd like to be able to provide an exact listing of the files for the EU, Australia, Middle East, South America, etc., vehicles.
The nuvi updates contain some large files that are not needed in the US region, and it would be nice to know which files can be safely omitted from the other regions if they're in the same boat.
These maps are starting to get pretty big, so being able to cull out the unnecessary fluff may allow everyone to get a few more years worth of updates...
I would like to have the information from both Garmin systems from each region, the CTP11/12 system from the 2011-2012 vehicles, and the CTP2013 system in the 2013+ models.
This should only take a few minutes of your time, and nothing will be modified in the radio.
The information needs to come from virgin radios that have never had a map update.
Here is what I need from the radios. I'll split it the procedures for CTP11/12 and CTP2013:
To identify CTP11/12 vs CTP2013
Go to the main "Where To?" screen:
CTP11/12 - "Where To?" icon is a magnifying glass.
CTP2013 - "Where To?" icon is an arrow.
CTP2013
CTP11/12
Please PM me with the results. I'll update the following list as the results come in.
Still need:
Australia CTP2013
EU CTP11/12
EU CTP2013
South America CTP11/12
South America CTP2013
Middle East CTP11/12
Middle East CTP2013
Completed:
US CTP11/12
US CTP2013
Australia CTP11/12
CTP2013
- Navigate to "Settings -> System -> About".
- Tap and hold the hidden button in the lower right corner of the Nav screen, just above the bottom-right Uconnect icon for about 10 seconds to enter the "Developer Menu"
- Scroll down and tap the "File Manager" button.
- Browse to "Disk 0:\Garmin\ASR.
- Record the file name of the "********.SRX" file.
- Tap the "********.SRX" file and record the file size.
- Go back to "Disk 0:\Garmin\ASR".
- Record the file name of each of the "********.ASR" files.
- Tap each of the "********.ASR" files and record the file size.
- Browse to "Disk 0:\Garmin\JCV".
- Record the file name of the "*********.JCV" file.
- Tap the "*********.JCV" file and record the file size.
- Browse to "Disk 0:\Garmin\SID".
- Record the file name of each of the "*********.SID" files.
- Tap each of the "*********.SID" files and record the file size.
- While in the window that displays the SID file size, tap the three-horizontal-bar icon in the upper right corner and select action "Open with Text Viewer".
- Somewhere in the top of the file, there will be some type of identifying string, like "PointAddressing" or similar. Please record this string.
- Go back to the "Developer Menu", and scroll to "Test Mode".
- *Different in some radios depending on Garmin software version
- Older versions:
- Tap the "Next" button until you see a button that is labeled "More"
- Tap the "More" button and record the ****.** map version that is installed.
- Exit Test Mode when finished. Garmin module will reboot in a couple of seconds.
- If you get into the video test mode and start cycling through the color screens, tap the upper-right corner to exit.
- Newer versions:
- Tap the "Next" button until you see the list of files installed
- Record the ****.** map version that is installed.
CTP11/12
- Tap the speed indicator in the bottom-right corner of the Map screen.
- Tap and hold the hidden button in the center of the big circle for about 10 seconds to enter the "Developer Menu"
Still need:
Australia CTP2013
EU CTP11/12
EU CTP2013
Middle East CTP2013
Completed:
US CTP11/12
US CTP2013
Australia CTP11/12
