1 - 15 of 15 Posts
What's the widest tire someone has fit on the stock 20 inch rim? I figure a 275mm 0r 295mm (40 series) tire should fill out the rear nicely while you're limited to a 255/40r20 on the front end.
vvv90
what are you going to run when you go through those AS's???
come to think of it...
that creates another question...
aren't you through them yet? :biggrin:
· Premium Member
HA! .... Yeah, I'm surprised I'm not yet. That ESP sure does a good job!
Since the AS's are all weather tires, I might just keep them for the winter, and then install some Ultra High Performance tires....275 in back, 255 in front.
I do REALLY hope Nitto of BFG starts making some drag radials in 20's....I'd love to be the first to break 12.9 with a stock motor. :D
Be aware on the 06 models with the tire monitor sensors that if it is like my c5 corvette if you go much outside of stock diamater it will throw a code for the wheels and eventually go to close loop if you don't correct it.
Salty
· Premium Member
ReCoRd TiMe said:
Hankook makes a pretty good tire “VENTUS”, have them on my F150 SVT,
don’t know if they make the size.
Hankook surely does make that size, I have them on my C all around. 275/40/20 Ventus ST RH06 (W) rated tire. The tire is as smooth as the OEM without the floaty feel.
Front?
I've seen 275's in the rear and they look awesome. I know the front diameter is limited but has anyone tried a 275/40R20 (28.6 inch diameter)? You could run the same combo all the way around for easy rotations.
psaltonstall
that is a great point!
anyone have a problem yet?
Motohead any problems with the sensors and codes?
Thanks guys!
great stuff!
jketron...
you'll be the 1st to run with 300+ plus on yours...
with all that power... :biggrin:
vvv90 said:
Feeling a little inadequate are you? We all knew the blower was a compensation. :D
Damn VVV, you made me spit my afternoon beverage on my screen. CLEAN UP EISLE 5!! LMFAO!
No problems
I have only run the 275's in the rear, I maintained the stock All Season 245/45 Gooyears in front.
I have had no issues. I re-used the stems for the air pressure monitoring system. The system accurately reflects the correct pressure.
I have not had any trouble codes from the ECM. I did have to try several tire places that could actually mount 20's.
BTW, your can still 'break loose' the 275 Pirelli's without much trouble.
1 - 15 of 15 Posts
