1 - 1 of 1 Posts
I am getting water build-up on the inside of the rear car door wells. The water is not going into the door itself or the car interior - its just sitting in the well at the bottom of the door when the door is closed.
The water is basically building up on the inside side of the weather stripping at the bottom of the door - it's like the weather stripping is creating a dam that prevents the water from flowing out the bottom of the door to the outside ground.
But when I open the door after it rained, about 2-3 ounces of water suddenly drops to the ground.
It is happening to both rear doors - so it sounds like it should be a known water leak issue that is somehow draining outside rain water to the inside side of the lower weather stripping and allowing it to pool up at the bottom of the door well (but not in the door itself)
Any ideas?
1 - 1 of 1 Posts
