I found 3 gallons of water in my trunk. Shorted some fuses. Carpet is soaked on both sides of the spare tire well.
I have seen a couple of threads for similar problem but no one has identified a solution.
Does anyone know of a comon problem and its source? I'll be bring it to the dealer this week.
Under warranty? Take it in! Let them figure it out.
Try running water over the rear area of the car with a hose. Make sure the inside roof of the trunk is dry before starting. If there is a leak you should be able to spot it by seeing where the water is sneaking in.
Check the seals around the trunk.
You may have alos left the trunk open a bit by accident.
However, as mentioned above if you have warrenty (bumper to bumper) take it in because of the electrical issues that came around.
