1 - 15 of 15 Posts
ehh you can remove the air silencer, thats not gonna give you that much more power, but itll increase the sound, and perhaps improve throttle response. try a search, theres a thread on it in the FAQ section i believe.
other than that, theres nothing you can do for 'free'
if you want to pinch pennies, id say-
cheap exhaust mod ($50-$200, depending on who you know)
air intake ($100-$300)
jet chip, stage 1 ($150-$250)
those are just some 'cheap' mods you might want to consider, and remember christmas is right around the corner larry
welcome to the forums!
· Banned
Are you looking for daily driving mods, or drag strip mods?
Free (or nearly free) drag strip mods include: Remove fuse 17 to defeat tranction control; place a wire jumper to turn the fans on to cool the engine; buy two bags of ice to cool the intake; remove the air filter; take all unneccesary weight out of the vehicle; reduce rear tire pressure to about 26 psi; increase front tire pressure to nearly 50 psi.
For the street? Nuttin's free.
· Administrator
larry_chip said:
i took the #17 fuse out lastnight & the car felt the same way, NO Diffrence AT ALL. MFR Date is 07/05, someone told that after july 05 the #17 Mod didnt work? any truth?
It should work for you with an 07/05 MFR date. After 07/31/05 there was change in software and the esp system so removing fuse #17 doesn't work. My MFR date is 08/05, when i remove fuse #17, my car will sputter and pedal will go dead.
· Premium Member
Classy300C said:
It should work for you with an 07/05 MFR date. after 07/31/05 there was change in software and the esp system so removing fuse #17 doesn't work. I'll attest to that.
Well, it works .... but on your nerves by basically disabling your car:)
Classy, did you see the posts about the GSM "race ESP Mod"? Have you tried any other avenue .... or waiting for a programmer like me? But if I wasn't going to Iraq shortly, I'd get the GSM mod.
Have they come out with the second generation GSM trac mod? I'm beginning to run out of patience waiting for the programmer
Good luck in Iraq...Your a good man Cue!!!!
· Premium Member
Originally Posted by GSM
GS Motorsports is proud to announce that we have completed some key modifications for the LX platform 5.7 and 6.1
Race ESP Mod:
Completely deletes Traction control(esp) and Torque management on shifts points. This mod is worth nearly a 1/2 second in the 1/4 mile on the stock lx platform with No Codes..no more pause between shifts and no traction hold back from the ECU at the flip of a switch.!
Fan Control:
This mod Brings the fans on early keeping max temps on the motor down 10% or on the the 195 degree thermostat at crusing speed( no codes)
These mods will be aviaible from GS Motorsports as a complete package with as a pre made turn key modification with instructions for an easy install on any 5.7 0r 6.1 LX platform
Scott Quaranta
GS Motorsports
888-GSM-HEMI
Lifted from ESP thread, I'll check their website for info, but I haven't been there in a while and their website used to not have a whole lot of product info...
Any else with input??????
I just got off the phone with Scott from GSM and he told me that they should be taking order this Tuesday. They have one car completed and they want to run it for awhile before the put the second generation Race ESP mod out on the market
· Premium Member
Thanks for the info!!
1 - 15 of 15 Posts
