300С uses D1S bulbs with built-in ignitor for projector low beams. 9005 are used for high beams. 300 models without projectors use 9006 bulbs for low beams.
You are right! That's what I said in my previous post.There are 2 different bulbs to be used with the projector those with HID use the D1S bulb you mentioned and those without use the 9006 bulb as mentioned above by LSCto300C
Or do you mean that there 300Cs with projector headlights but without HIDs (stock halogen) and these ones use 9006 bulbs?
Didn't know your 300Cs may also go out without HIDs. I thought only 300s and Touring models with square headlights could have halogens. Cause here in Europe all 300Cs have only HIDs.I was saying that both you and LSCto300C are correct in that 300c with projector came with either the D1S HID light or the 9006 halogen bulb for the projectors.
