The first step is a perfect hub fit. The new wheel should have a 71.5mm hub. If not then you need centering rings to reduce a larger hub size down to 71.5mm? Never hear of needing to shave studs. Did you remove the couple clips around studs?I got 5x114.3 Strada Venti's and i was having vibration problems due to the wheel no fitting around the hub. I put adapters on the front and that fixed my problem. Had to shave studs down just a bit, but i am riding smooth now
