Hello all,
I am pleased to see that a Detailing section was added to this forum as detailing is a major hobby of mine and the object of my obsession happens to be my Midnight Blue 300C. I figured I could pass along what I've learned to my fellow 300C enthusiasts by explaining the difference between a wax and polish as these terms are often used interchangably (and often incorrectly).
Pure Polish
A pure polish is designed for removing swirl marks, scratches, cleaning the paint surface, leveling paint (i.e., blending repairs & removing orange peel), and finally for improving surface gloss. There are two different types of pure polishes, abrasive and chemical. The abrasive type contains very small abrasives that break down as the polish is worked into the paint. There are many different grades of polish. The same polish (more coarse) used to fix a scratch is not the same as that used to improve surface gloss (very fine).
The chemical type is relys on chemical cleaning of the paint surface and as a result has very limited in it's ability to correct surface imperfections.
There is one key point about a pure polish and that is that it does not add any protection to the surface. A pure polish always needs to be followed up with a layer of wax in order complete the job.
Pure Wax
A pure wax has NO cleaning ability and is basically a "top coat" that helps protect the paint and adds depth and shine to the surface. There are actually two types of wax, Carnauba (derived from nature) and Synthetic (born in a labe). Each one of these has it's own set of pro's and con's. The Carnauba offers more depth while it's less durable. The Synthetic offers more durability while providing possibly more shine (albiet at the expense of depth).
One step wax products (a.k.a. cleaner/wax)
This is the most commonly used type as it combines a wax and polish in one product. The advantage is one application and you're done. However, you won't get the same level of depth and shine or durability as compared to using two discreet products.
Most "over the counter" stuff you get at Pep Boys is labeled "Wax" but has some cleaning capabilities as it's design for the non-enthusiast. The following are some good examples of cleaner/wax products:
Pure Polish
Pure Wax
