1 - 2 of 2 Posts
So I'm new to adding aftermarket tires and rims. Or is it wheels and tires? I have a 08 300 lx, and I'm looking to add sone 20s. Does anyone know if the clearance and turning will be OK? Again, new to all this so I'm sure my question sounds stupid. LoL. I know bolt pattern is 5x15. As long as the pattern marches, will any 20s fit ok?
You'll need the proper offset of +24mm or thereabouts. A few millimeters either way won't matter.
Also, the wheels will need to be hub centric to avoid wobble. Wheel centerbore should be 71.6mm or so.
Wheel width of 9" is perfect for these cars unless you want to go to a 10" on the back. Offset may have to change in the rear to avoid rubbing with a 10" wheel and a 20 inch tire with a section width of 295 or larger.
1 - 2 of 2 Posts
