That's the place.
But why? Is your tranny leaking? If so something needs to be repaired.
And if you do it you will need to buy a dipstick (search the forum for what and where) so that you can detect the level. Cost of a dipstick is something like $70!
I have the dreaded o-ring disease, I believe. I have to drive 30 mins to get it in to service, so I was planning on having everything on hand in case I need to top it off before I head out. I may just drop about 1 C in anyway.
Thanks for helping verify where the transmission fluid is added.
You need the dip stick to measure it ,Buy it at ETOOLCART.COM miller special tool dipstick 9336. The dip stick has mili meter measurments 30mm ,cold 50 mm warm, 70 mm hot
It looks worse than it really is, so don't add more than a couple of ounces. Overfilling can cause damage. Then skidattle straight to the stealership to get it fixed.
