1 - 1 of 1 Posts
I forget what winter is this year. We haven't had any yet. All these tips are common sense, but it was just posted on the DCX media site:
2006 Winter Driving Tips
Aspen, Colo., Feb 1, 2006 -
Always wear your seat belt — Seat belts are necessary in all seasons, and especially when conditions are not ideal
If your vehicle needs a tune-up, do it before winter — The little things (spark plugs, bad hoses and belts) can leave you stranded in the cold weather. Also, make sure to get your battery and cooling system checked, as the winter months are extra tough on them
Always keep your gas tank at least half full — If you get stranded for any reason, your engine is the only source you have to rely on for heat
Always take a cell phone with you — This is truly a time to take advantage of this modern convenience. If you get stranded, it will be much easier to call for assistance from your car, as opposed to walking to the nearest gas station. Don't forget the car charger for your cell phone
When driving in the snow, do everything slowly — Even with the best equipment, driving in the snow can be treacherous. Accelerate, turn and brake slowly and gently
Be sure to check the weather before heading out on a long trip — It's best to be aware of the weather conditions you may encounter on your journey. It's also wise to build some extra travel time into your itinerary, in case you run into harsh elements that may slow you down
Be aware of potential icy areas such as shady spots and bridges — Even if it's blue skies and sunny, it's still icy on bridges and in the shade through the winter months
Keep a safe distance of at least five seconds behind other vehicles — In snowy weather, you need more time to react if the vehicle in front of you suddenly brakes
By law, do not pass snowplows on the freeway — In winter, these vehicles should be treated with the same respect as emergency response vehicles
Clear snow and ice off your vehicle before driving — Visibility is key in poor driving conditions. This also will help avoid sheets of ice flying off your vehicle and hitting the vehicle behind you
Keep a winter car kit in your vehicle at all times — It's always a good idea to keep emergency items (flashlight, blankets, matches and non-perishable food) in your vehicle in case you get stranded for an extended period of time.
Rambit
1 - 1 of 1 Posts
