1 - 1 of 1 Posts
Every so often when it's 5 degees or colder my 2.7 300 won't shift into overdrive. I can drive forever and it won't go into overdrive, but if I pull over, turn off the car, restart it, it will then go into OD.
Anyone else come across the same problem if so what is the answer. Dealer is having no luck. scaned it and no codes to indicate problem. It happens always at the wrong time( such at night when their closed I can't get there when it happens. Any help would be appreciated.
Thanks Jonnierock
1 - 1 of 1 Posts
