1 - 20 of 20 Posts
OK, so my wife asked where the battery was on the SRT8 and I told her, of course, in the trunk. So she asked since you couldn't open the trunk with a key, what happens with a dead battery (a REALLY,REALLY dead battery)? How do you get the trunk open to change the battery? Don't the key fob and dash button still rely on 12 volts to open the trunk?
Cant you get into the trunk via dropping down the back seat? Also, what about the battery in the front of the car?
Yep, the battery's in the trunk. Want a really stupid design? My Mom's Buick has the battery under the back seat!!!! Let's see... leaky battery -- oh, let me light a cigarette.
It is not stupid. It is actually smart. It is called weight distribution. Makes car better handle and grasp the road. Front is already too heavy. I think all bimmers have the battery in trunk and 3 series has some of the best weight distribution among production cars.
Pull down back of rear seat on left side, slide into trunk and pull safety latch as explained above.
can't you open the door with your key and then hit the trunk open button inside, I don't think you need power for that to work?
The trunk button is electrical, therefore dependent on the battery.
And as far as weight distribution, fine -- put the battery in the trunk, but don't put a hydrogen gas-producing device in the passenger compartment, turning the car into a bomb. They're enough of that already. That stupidity is perhaps the reason GM is scrambling just to survive.
I have a solution to get into the trunk! Video included.
I just created a video of how I was able to get into my 05 300C trunk with NO battery installed in under 5 minutes! But it won't allow me to post the link yet, since I am new.
Error I get:
You are only allowed to post URLs to other sites after you have made 4 posts or more. Posts in the OffTopic section do not count.
Error I get:
Therefore make 4 posts!
Reactions: Immabos
You only need 2 things to pop your trunk without a battery installed, or if your battery is shot.
#1. A 12 V Car Lighter Adapter
#2. A 12 V Power Source (I used a rechargeable battery from a cordless Skil drill)
Take the 12 Volt adapter and plug it in the the auxiliary power source underneath the center console/arm rest.
Touch the positive wire from the adapter to the positive side on the drill battery, and negative to negative.
Once you have it connected, your dash lights will light up like Christmas! Hit the Trunk button on your dash or your keys, and boom! Your trunk is now ajar.
I will post link to video next.
Trunk button on inside works on battery. Got into the trunk but the open er that hangs down is gone so don't know what to do next. Is there a latch that pushes open? My friend got into the trunk but does not have the strength to push the latch. This is from a 72 year old woman
I have a jump box that has a adapter that plugs directly to the 12 v socket . Didn't work . I must have a more serious problem .I'll have go to rent a kit to crawl in the trunk and pull the emergency release . I had my car towed to my mechanics shop let him figure it out.
1 - 20 of 20 Posts
