hi
i am french and glad to have found this forum...
i have a problem with my xenon headlights..when i switch them on, it blinks!!the right flash and switch off then switch on..and after it is the left one ..can someone help me.? ( sorry for my bad english..):pat:
hi
Votre mauvais anglais est bien meilleur que mon mauvais français, pas besoin de s'excuser. That was hard enough, I'll do the rest in English.
Are your Xenons factory or aftermarket? I am no expert on xenons but the problem you have I do not recall seeing on any factory Chrysler Xenons in 4 years on this forum. Most, if not all problems are related to aftermarket xenons with improper wiring, ballasts, or bulbs. If they are aftermarket I don't have any idea on what to do.
If you have Chrysler Xenons, you can contact the local dealer to see if there is a TSB (technical service bulletin) that addresses your problem.
I Googled "Chrysler xenon TSB" and did not find anything.
Bonne chance!
sur des sites Internet réfléchir à l'aide d'un faux nom plutôt que votre vrai nom
hello,, im having the same problem on my 300c 2005,
i got the car used and after 2 weeks my light wa acting weird.
pleas helpe me with this problem.
my xenon are original factory ones..i saw my local dealer but they don't know what is the problem...they want me to buy two new headlight with module ballast and bulb..more than 2500 dollars!!!
i d like to find a cheapest solution..
It does sound suspicious for ballasts, you might try bulbs if not too pricey.
Try going to a wrecking yard that has units from a car that was rear ended for a much better price.
Welcome to the forums. Sorry to hear of your headlight problem.
Here is a thread (below)that seems to be describing the problem you are experiencing although it's with HID lights. Near the end of it, you will even see a video someone made of the this very [roblem. The solution does seem to be a new headlight assembly which is very expensive. Check out the whole link when you have some time.
http://www.300cforums.com/forums/pr...headlight-malfunction.html?highlight=blinking
im looking for a solution to my problem with my xenon lights on my 300c,
when i turn them on only the left side go on blue and the right one dims down alot and turns purple, its a verry weird problem,, what is a good solution for this problem???
