361 - 380 of 692 Posts
i am perchasing the best of the best (slam specialties 300c bag kit) and then of corse modifying it to lay pinch.
i used this name to match my other names on other forums i have 4 minitrucks some are body dropped and what not and lay on the ground ill post pics in a few
ohh and the ride is amazing...i was truelly supprized i swear i dont even notice...it might be a hair louder and mabey a hair rougher but with stock suspension i love it
(bags soon to come then ride will be pillow soft)
24s on 275/25/24 would they be ok with a 1.5" drop. with just the control arm bolt filed down.. im looking at lots of vids on youtube etc..since no one in my area has 24s is the turning radius messed.. will it rub or crack truning on a hill etc... my old car had this with 20s lowed..24s look sick but for a daily driver.. im thinking it should be good to go.. with cautious driving..
mine does not rub at all, and i plan on lowering it...the only problem being i dont think i will be able to with these rims they are too wide... if i had 9" rims they might tuck...but if i lowered it even 1" as is...i would surely smash in the entire fender if i hit a bump because there is no way they will tuck unfer the fender...mabey if you could give it some negative camber or different offset...
24x10 offset +13 HEEELP
Hello!
Iam new her at the forum, iam going to order a set of 24s whit tires.
I have look at this set on ebay
24" INCH 800 RIMS & TIRES CHARGER MAGNUM CHRYSLER 300 : eBay Motors (item 290330464434 end time Mar-07-10 09:41:35 PST)
They are 24x10" whit the offset +13 and iam going for 275, 25, 24
My question is are they going to fit?
I a have shave the bolt and are going to drop the car whit eibach 1,5 and
if i have to iam going to roll the fenders as well.
Are the going to crack my fenders?
iam worried about this!
Sorry about my english iam from sweden..
Best regards /Joel
Discussion starter · #367 ·
Hello!
Best regards /Joel
Those rims should work. You should def roll the fenders if you're gonna drop. R u worried if rolling your fender will make your paint crack? Well, not if it's done properly.
Thanks for the fast answer!
Noot really but iam worried about that the rims are 10" width and whit the offset +13
My question is:
Are this setup going to work on a lowerd car? isnt this rim to width to mount in the front?
Will it work if a roll the fenders?
Thanks/Joel Ek
with a 10" wide rim there is almost no way they will fit under the fender...unless you buy or make some aftermarket upper and lower control arms that can bring the tire inside more...or by cambering in the upper control arm so much that you would be riding on sidwall
in other words rolling the fender wont cut it...time to find some special 9" wide with a custom offset
im pretty sure with 10" wide its gonna rub on the 'control arms' up front, so you'll need a spacer. And it'll stick out a bit, so not sure how that will work out when you lower it.
Hello!
Best regards /Joel
Wrong!!
And....Wrong!!
It will work no problems just as long as you roll your fenders...Need proof? Here ya go
24x10 with a 10mm offset!! Eibach Pro-kit rolled fenders
i dont at the moment...but you are absolutly correct it does stick out (about 2-5mm outside fender)...i have +13 offset and a 1mm spacer in front (just a washer over every lug) because it does rub the control arm with +13 offset and 275/25/24...rolling the fender would do me no good it sticks out far too much to tuck without custom a arms
these are facts with this spacificsetup (275/25/24, 24x10, +13 offset)
hope i was of some help ill try to get picks up soon but some ******* slashed 3 tired in downtown seattle at midnight...the cop caught him in the act and left me a card...but apparently there is almost nothing i can do to get my money they said i can go to small claims court but it is highly unlikely i will get any money from the suspect LAME!!!!!!
Okey here is divided opinion in this question. I have to check this out before i order my rims.
Thanks for your your advise!
im tryna look at the front wheels on that charger, and they just dont look 10 wide. i might be wrong.
Anyways mine are 275/25/24, 24x10, +15 offset.....needed spacers in front cuz of rubbing on control arm. prolly stick out a good half inch.
I was trying to find a thread where you had your specs or wheels on your car but couldn't. What wheel do you have? And those wheels are 10" wide
